メインコンテンツにスキップ
ハードドライブもしくはハードディスクに関する修理情報です。ハードドライブは磁気データ記憶装置です。 低コストでデータ密度が高いため、ほとんどのデスクトップ、ラップトップ、およびサーバーで使用されています。
143回答 すべてを表示
Why does the drive stop responding when connected to the USB sometimes
Sometimes the drive is not recognized after it is plugged in. Even though you can feel the disk rotating, the light does not glow nor is the drive recognized by your computer. This behaviour erratic.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Once this has happened it can cause master directory damagethat will increase problems until the drive is hosed. Use Disk Utility->repair disk for directory damage, back up your data. N.
さんによる
コメントを追加
3件の回答
ベストアンサー
I would suspect that the drive is not receiving enough power at times. Does this always happen at the same USB connection? If so does moving it to another USB port allow it to work properly? Of course if the drive is powered by external means I would worry the drive may be failing. Ralph
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Once this has happened you can have Master Directory damage that will cause continued problems. Use Disk Utility to repair directory damage. N.
さんによる
+ agreed, different ports offer different power levels
さんによる
コメントを追加
You may check your Energy setting for 'Put Drives to Sleep' and ensure that is off.
Update
You could have a bed drive (even if new). Look, if a company makes a million of something there is a good chance that at least one of them is bad. I have a FireWire drive that is externally powered and sometimes it just stops. I think it is the drive itself.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The energy setting just made the difference for me. I was using this as a bootable volume for a new snow leopard computer, and the default settings for both battery and power adapter were turning off the drive whenever I tried to use it to boot. Helpful tip. Thanks.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rakeshv79 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,297
