Why are these HDD connectors not the same?
Here is the computer connector and the hard drive. Why are they different?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your Toshiba unit uses a PATA interface for it's hard drive. Sadly, the drive you have here is a SATA based hard drive which is a newer standard.
These drives are not interchangeable as you have discovered these use very different connectors.
このアンサーは役に立ちましたか?
Thank you!!!
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 132
