メインコンテンツにスキップ
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
64回答 すべてを表示
Why is my CD/DVD drive not working?
Whenever a put in a CD or DVD into my computer it does not read the disk. It makes a whirling sound like it is starting to read the disk but after a few seconds stops and does nothing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
選択されたソリューション
It's possible that the CD or DVD that you put in is damaged itself, and your drive is fine. Have you tried using the same CD's/DVD's in any other devices, such as a DVD player? If the disk also does not work for the other device, then something is probably wrong with the disk. If the disk does work in a different device, however, then something is wrong with your laptop's optical drive. Please reference the following link if this is the case. Dell Inspiron 1545 Troubleshooting
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Kyle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,781
