メインコンテンツにスキップ
A push button control blender with stainless steel blades manufactured in 2011 by Oster.
Why is my blender not turning on?
I have turned on my blender and the blades do not turn when I press ON or when I select a speed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
It is possible that your blender is not plugged in. Check to make sure that your blender is properly plugged into a operating power outlet and then try to turn your blender on again. If your blender still will not turn on, your power cord may have faulty connections. Look at your power cord and see if it is broken or torn. If it is broken or torn you will need to replace the power cord with a new one. If neither of these solutions work to get your blender to turn on, you may have to replace the circuit board.
Click here for further help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Victoria Mark さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 6,844
