メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
Water spilled on my laptop and now became very slow
Water spilled on my laptop and now became very slow and work through the charger and the battery just do not charge also...And I want you to help me to know how to fix it ???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
3件の回答
最も参考になった回答
Follow the tags at right and you'll see what you're in for (major DIY project). Easier way (still very advanced as you have to completely disassemble and reassemble the entire machine) replace the logic board. (You might even be able to upgrade to the latest processor/graphics package for your model year if you own a base model).
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
It happened two months ago, the keyboard still works and the water did not enter on the keyboard and the screen also !!
さんによる
But the battery was not working and change it with a new one did not work well and are there programs to increase the speed of the Mac
さんによる
There are no software fixes for hardware issues - if the slowness is because you have less than 10GB of empty space on your boot volume, remove large files until you have more than 10GB free.
さんによる
I've cleaned the mac inside and become better and improved speed, but not like before damage ..The problem now is the battery i see the battery information the Cycle count: 388 and the condition: normal ...!!!
さんによる
Yes the newer Apple Batteries can last up to 1000 cycles though performance will deteriorate as you reach the end of life.
さんによる
コメントを追加
I also have the same issue. It's faulty temp sensor in the trackpad. I just replaced the logic board and realized that it wasn't the board to begin with but the sensor.
I had two other customer laptops with the same exact issue (very slow, fans running high, SMC error in the diagnostics). Apparently the way the liquid spills, it hits the trackpad area.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How can I know whether the faulty temperature sensor is in the trackpad or somewhere else?
AHT error reference codes: PFM006, NDC001, PPN001
MacBook Air 7,2 (early 2015)
Damage occoured while it was in a backpack with a leaky water bottle.
Fan is on max. kernel_task is using around 2-12 % CPU.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I would give this utility a try as its much clearer than AHT on whats happing: TG Pro for less than $20 US its worth it.
さんによる
コメントを追加
回答を追加する
aziz mneer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 27,150
