How to recover data from hard disc?
My laptop suddenly stop working n it's not detecting my hard disc..
Please guide me
Do you have another working machine alongside with the laptop's hard drive in question. You can download Stellar Phoenix Windows data recovery software on a healthy PC and attach the laptop's drive with cable. Run the software and scan the laptop's HDD with the software. If the hard drive is detectable then software will recover files from it. The other case around, if HDD is physically damaged then it would be difficult for any software to recover files. In that case you may need a data recovery services help. hope this helps!!!
このアンサーは役に立ちましたか?
According to me, you may connect your HD to another computer and check if it is detected and that the problem doesnt come from your laptom motherboard. IF it is, but that there is no data on it, you will find a bunch of data/partition recovery softwares on the internet and docks/adapters can easily found below $30, such as this one [リンクされた製品が存在しない、もしくは無効: IF107-108-1]
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 324
