メインコンテンツにスキップ
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
Device confusing power cable for an MTP and wont charge?
I was intermittently getting a red cross over the battery icon coupled with a "MTP initialization" message when I would plug in the power cable to the device.
Im now getting this all the time preventing me from charging the unit.
I have no idea whats going on with it. Am dreading having to take it somewhere and how much that may cost me.
Any help would be greatly appreciated!
X
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Danielle Rush, the first thing to try would be to reset your tablet's factory settings. Try a different cable as well. If that does not work, then it is possible that this is caused by dust, dirt, corrosion or other contamination of the USB port. Use some isopropyl alcohol and some compressed air and clean out the port. Do not stick anything in it since that my bend the pins. Lastly, it is possible that some pins of the micro-usb port have been disconnected from board so the tablet does not receive charge, and it mistakes the connection as a computer instead of a charger. This would require a disassembly and a possible resolder of the micro USB port. The MTP scanner is the media scanner that runs when the tablet thinks it might be plugged into a computer instead of a charger. More information about that on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My Samsung Galaxy TABLET threee
wont charge or open its like its broken or something plz help mee its been 3 month
can we open that tablet if we can plz telll me by open i meaninside open where its connected from == ==""i
plz hope someone have an idea how to solve my problemmmmmmmmmmmmmmmm someone plz help
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I held the power button down for 1 min. Plug the charger in. Held the power button down for 30sec. Now the red x is gone and it's charging.
さんによる
コメントを追加
when the red cross is over the battery it will still charge when the screen is asleep. But not when u are using it. this happened to my tab. I bought a new cable/lead and it works perfectly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Danielle Rush さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,796
