メインコンテンツにスキップ
Optical drive swap for SSD
I'd like to swap out the optical drive with a SSD in a caddy to my powerbook G4 12" aluminum. I can't seem to see if the standard, SATA to IDE caddy will fit before I dismantle the entire computer. Thanks for any information.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Your between a rock and a hard place here, sorry
Sadly, there is no frame available for your system. And the SSD will be too fast for your system causing other problems.
I also wouldn't do it as your OS (OS-9 or early version of OS-X for PowerPC systems) does not have the needed support of SSDs TRIM services so you'll wear out the SSD out prematurely.
I would focus on upping the memory if you can and if you can update the hard drive to a larger drive (if you have limited free space) to gain what you can with this system.
Otherwise its time to safe ones pennies for a newer system (even a used Intel based model).
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joeblois さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 174
