How do I change the MAF (mas air flo) sensor?
Does the 2001 Honda Accord have a MAF and where is it and how do I clean or change it?
that depends on the used engine. the 4 cyl. has a MAF and the 6 cly. has a MAP sensor
maybe this helps you (the engines are not always changed after a modelchange): http://www.driveaccord.net/forums/showth...
このアンサーは役に立ちましたか?
2.3 accord does not have a MAFS, it works of the MAP sensor.
works off of MAP sensor, has no MAFS.
thx
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 8
過去 30 日: 47
今までの合計 17,110
1件のコメント
Seriously? Are you sure it is bad? There will only be tiny bits of carbon in it. Why do you think you want to clean it?
Dave さんによる
