メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
How can I clean my laser disc drive?
Hi there!
I have had my MacBook for almost 4 years and had no problems until recently. A few days ago, my DVD/CD reader drive decided to stop reading discs. I saw that many other people online have had this issue and that it might possibly be because there is dust or debris within the drive.
My Macbook ejects and DVD or CD that I insert after making a weird reading sound (not smooth sounding, as it did previously).
I saw your iFixit guide on replacing the drive, but if I wanted to just clean it, what would be the proper procedure so that I don't damage the drive (any more if it is damaged) in the process?
Do you think it's even possible that it's just dirty since it's not reading CDs or DVDs or do you think it's more likely that it's actually damaged?
Thank you for any help you can give!!
-Amber S.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hard to say if the drive is bad. With that said, you might try cleaning the lens by getting a CD/DVD cleaning disk from Radio Shack. This disks have a micro brush that can clean the lasers lens. You could also try using some can'ed air. A short blast or two should do it (make sure you don't spray the liquid)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Amber さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 887
