How to fix Galaxy GT-P5113; won't turn on after water spilled on?
How can I take this apart and clean it?
Steve Holland, Here is a decent teardown video. Once you have it disassembled, check for corrosion, burned or charred, as well as missing components. Clean every part with 90%+ isopropyl alcohol. do not forget all cable ends and connectors. Replace the battery then re-evaluate. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Thanks! We'll try it in the morning and let you know how it goes.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,300
