メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2011年にHPが開発した、webOSプラットフォームを搭載したタブレット。9.7インチのディスプレイを備え、16GBまたは32GBのモデルが販売されています。修理は直感的ですが、時間と根気が必要です。
HP TouchPad won't turn on
HP touch pad won't turn on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 21
6 件のコメント
My touchpad charger got faulty... I got charger now and it's been displaying the charging sign. But it refuse the to come on.
さんによる 共有
When it come on it pop a question mark what I’m suppose to do???
さんによる 共有
I have losted my Touchpads ac adapter and its wire now i cant charge my touchpad please give me a solution to charge my touchpad
さんによる 共有
How much is a charging port
さんによる 共有
I did I hard set to get my hp touch pad to come on. But when it came back all I see is a batter with a question mark in the center of it. What dose that mean? Is my batter low or dose it need replacing
さんによる 共有
1以上のコメントを表示
コメントを追加
7件の回答
最も参考になった回答
when you plug it in is there any indication of it charging?
Update
try holding down the power button for 60 seconds.
leave device plugged in for 24 hours.
try holding down the power button for 60 again and try to start.
If you still don't have any power you may have a bad charging port:
Intermittent USB Power Port - Common Problem
You can send it to us for diagnostics as well.
www rockhoptec com
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If your HP touchpad is not charging, it may be that you have to reset your plugin i.e. the cylinder that you plug into the wall. To reset it, unplug the cylinder from the outlet, remove the usb cable. You then twist the end of the cylinder with the prongs counter clockwise, then you twist it back to its original position. You don't have to twist it that far until you reach resistance in either direction.
There you have just reset your plugin, so plug it in directly to a wall outlet and hopefully you will be able to charge your touchpad. Leave it plugged in for 2 hours to see if it worked.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
This is the first time I have ever heard of resetting the plug. It worked.
さんによる 共有
I haven't used mine for a really long time and it won't turn on I charged it and the little home button is going back and forth
さんによる 共有
Mine too frustrating
さんによる 共有
コメントを追加
Mine just did the same thing. I held down the power button and mashed the home button for 15 times (actually I think it was more than that) but I just kept pushing it until the Touchpad came to life. Works great now.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for the tip. Had same problem and reset it following your instructions and it worked.
さんによる 共有
コメントを追加
I have two Touchpads that had this problem. Note that when the Touchpad is in this weird mode, the charger will NOT get warm when one attempts to charge the Touchpad. It's as if there is no charger connection to the Touchpad.
My solution was as others have mentioned. Hold down the power button while rapidly-pressing the home button about 15 times. Then connect the HP wire charger to it. It flashed the sides of the home button alternately, indicating it was seeing the charger. Later, it displayed the battery icon. After that, it boots the OS. If the battery is completely dead, try it with a charger connected to it.
When I tried to use a lower current charger, it gave me the "use the original charger" warning.
I will note that the situation that led to the problem (in both cases) was sitting the Touchpad on a Touchstone charger with the cover closed. If the Touchpad is moved, the screen turned on, which used more current than the Touchstone charger could provide, eventually draining the battery to zero charge.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same charging problem, i used my block from my iphone 5s, and a short usb cord it seems to be charging the button at the bottom of the touchpad has a white line goin bac and forth so ,iwill wait and see .
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
My HP is fully charged. I plugged it into the USB drive on my laptop to reboot finally my HP tablet came on had to reset Wi-Fi 3 min later screen is black again.
さんによる 共有
Forget to addt ablet started out with black screen, then tried trouble shooting by rebooting via Laptop came on miraculously reset Wi-Fi 2min few minutes later screen is black again tablet is on. Somebody help me please.
さんによる 共有
コメントを追加
This always happens, to me about atlest
Over 30 times . I do this . I let the tab plugin still and do master reboot :
Hold POWER and HOME button down
till it reboots . If it dont reboot and shows msg saying Power cord Is not the right one for your tablet , thats a good sign , it means your tab still have some batt life in it .
Try NOT to ever let it drain out of batt.
Let it sit for about. 1-2 hr charging ,
It should reboot on its own if its been charging, if this still dont work .
Keep doing the power and home button hold down,. It should normally reboot any were from 10-30secs
Hope that helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Mines i think its a network problem because of similarity i dont know how to fix it but i am trying
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lolazhere2 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 55
今までの合計 51,135
