Samsung Galaxy Ace Plus is shutting on and off by itself?
My phone ran out of battery and I put it to charge, after charging I turned on the phone... The phone shows Samsung, then the model and shuts off by itself and goes on a loop of turning off and on.
I thought it might be the battery so I bought one... Same thing happens when I installed the new battery, then if thought it might be that the phone doesn't charge so I bought a battery charger to proof that theory. I charged the batteries only to discover that the phone goes on the same loop of turning on and off by itself. Does anyone have any idea what can it be? Thank you for any help you can give me.
この質問は役に立ちましたか?
3 件のコメント
My phone turn off that day and wont turn on until now . But when i try to start , it only came out the battery symbol and keeps vibrating .
alyaelias さんによる
My samsung galaxy J1 ace also had the same problem what should i do?
Mariso Kiri さんによる
Yes A solution is present if your mobile memory is full then it starts on and off and to solve this problem you can reset the mobile by pressing home button +volume up+power button and then reset the mobile from there and then mobile will work normall as it is...thankyou
Usama Rabbani さんによる
