メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
MacBook air shut down after battery change, smc reset didn't sort the
Hi guys!
i've just change battery on my MAB mid 11 13'' model 4,2
battery is recognized and working but after a while (some time with the charge around 82% or so system shut down) or even sometime only power up if it's connected to external power (magsafe) i tried to reset smc and pram nothing solved.
what i can do? i tried to reinstall the previous battery(original) and the problem doesn't exist.
any help please? :(
regards
Matteo
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Sounds like the power switching logic or the FET's them selves are having problems.
At this point are you up to servicing your own system? Have the correct tools and work area (ESD mat & strap)? Also do you know how to work on SMD devices and work with a sobering iron?
If not then I would go to an Apple Store or authorized service center and have them repair/replace the logic board.
Often this type of problem is due to static discharge around the Mag-Safe connector.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Did you try resetting the SMC? Follow this Apple TN Intel-based Macs: Resetting the System Management Controller (SMC).
さんによる
Well don't think it's a logic board... Because if I restore the original battery everything is working fine :(
さんによる
If putting back the old battery works then the replacement battery is defective.
さんによる
コメントを追加
I have the exact same problem. With my old battery everything works fine. I don't know what to do know, because I cant trust any other brand to replaced it with. The orginal battery worked for 5+ years and is still running.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
matteo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,914
