メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
Sleep light comes on, no chime no boot.
Hi there.
My MacBook shut down recently doing an iTunes update and did restart but not boot.
I ran AHT and it said this disc cannot be used with this Mac but it is the correct disc that came with the machine.
I did a PMU reset , and it shut down on the second chime and would not boot. No chime no post. The sleep light comes on and stays on, until I power off.
I can hear optical disc activity and nothing happens.
I have tried removing the ram and reinstalling it. And this does not work.
Holding the power button for 20 seconds without battery and power does nothing.
Any ideas? Thanks so much.
Update
Yes , in my case it was a failed GPU. Once reworked / replaced it came back to life.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Did you ever have a solution with this problem?
さんによる
So you replaced the entire Logic board?
さんによる
Yes , removed and replaced GPU with a rework station.
さんによる
コメントを追加
2件の回答
ベストアンサー
Here is a link to a troubleshooting guide from Apple. Hope it helps--if not let us know. Ralph
http://support.apple.com/kb/TS1367
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Great thanks. Will take a look.
さんによる
コメントを追加
Whenever I have had these symptoms with a MacBook it usually had something to do with flaky RAM or one of the RAM slots went bad (soldering) or liquid damage in the past, or dust in the slots obstructing the contacts when RAM is inserted... It could definitly be something completely different! But I might try insterting one ram stick in the lower slot then trying to power it up, then with the same stick try the top slot, and if this doesnt work try the same thing with the other stick of ram... If none of that makes it boot up properly then you just used the process of elimination to verify that the problem is not the ram sticks or the slots.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
markduff さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 3,231
