メインコンテンツにスキップ
iPhone 4のCDMA版モデルです。修理はそのままパーツに作業をしますが、フロントガラスとLCDはユニットで交換しなければなりません。16もしくは32 GB / Model A1349。
295回答 すべてを表示
締切られた回答
Replaced front screen and phone will not turn on.
I replaced the front glass screen with the digitizer, and followed the steps shown on the video. Everything went great and nothing was messed up, but after I went to turn it on, the phone would not turn on, so I plugged it in to the charger and all it did was make a beep every 5 to 10 seconds, but nothing came on the screen. I also tried plugging it into the the labtop and still nothing came on the screen, but the apple menu came up on the laptop, as if it was reading the iphone, and showed how much free space remains on the Iphone, and the phone still made the beep noise. Also before I replaced the cracked front screen, the phone was working fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
You will need to make sure the lcd cable is proporly plugged in and hasent popped out..
If all is plugged in and still nothing you could have damaged screen when installing.
You could always try old screen again see if that works
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Mitch is right hard reset first
さんによる
Have you tryed old screen..
Hard restart and restores arnt going to work just a waste of time..
Also check have you damaged any pins were you plug lcd in..
Start with old screen first see if that works
さんによる
Try your old screen in it see does that work then you'll no if the new screen is faulty
さんによる
Can you try the old screen?
さんによる
コメントを追加
You should start with a hard reset.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried the hard reset when the screen did not come on, and that did nothing. I also switched the sound to off and just vibrate, and all I get when I plug it into the charger is a vibrate every 5 to 10 seconds. Is that normal?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the exact same problem. Anyone with any solutions
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried the old screen. It has the same problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 162
