Can you upgrade wifi card in airport extreme 2gen?
hey everybody
is it possible to upgrade the wifi card to something faster?
この質問は役に立ちましたか?
hey everybody
この質問は役に立ちましたか?
Your AirPort is currently an 802.11n compliant unit.
Have you checked and if needed updated the firmware? Apple did make some speed improvements within the Extreme's firmware.
Otherwise you will need to review your network's design to see if one of the interconnections are running slow. Where are you encountering slowness, Local or the Internet via your ISP?
このアンサーは役に立ちましたか?
I think by faster he means something 802.11ac or similar. I came here with the same question.
このアンサーは役に立ちましたか?
Sadly, the physical interface the AirPort card uses in this unit is not able to support anything newer. Time for a new WiFi Router.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 489
2 件のコメント
Can you give us the model number of your unit so we can see what you currently have.
Dan さんによる
sorry for not writing it, its a A1143 if its that you mean
andreas さんによる
