メインコンテンツにスキップ
2.6GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.2GHz)、3MB共有L3キャッシュ
120回答 すべてを表示
締切られた回答
Where are the power pads on this early 2013 MacBook Pro Model?
Since this Macbook Pro model is so new, I cannot find any pictures/information on where the power pads on the Model A1425 (early 2013) Macbook Pro logic board... Any help (especially with pictures) would be greatly appreciated!
Thanks!
UPDATED: Here are the photos of my logic board that I added below in my post. If someone could point out the two specific locations where a short is needed to power my MacBook on, it would be a godsend!!
Update
I don't know where the keyboard connector is on the logic board. Do you have a photo? I don't have the exact configuration shown in the link you gave me on my logic board.
ADDED: Photos are from my MacBook's logic board below. If anyone can point out where I need to short to power my MacBook on, it would be greatly appreciated. Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
John, just like machead3 mentioned, this can cause damage. Anyhow you need to shorten pin 5 (keyboard on/off) to ground. On the connector ground is pin 29 but you can use the metal standoffs since they are easier to touch and locate. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
How do you shorten the pin ?
さんによる
I use a jumper lead (a wire with clips at the ends) which is holding a sewing pin as its probe on one end to touch the solder pad as needed and the other in this case a metal frame stand off.
さんによる
If you are also working on an A1425 retina, you're asking the wrong question because this machine turns itself on automatically when you attach a functioning charger. The charger is your power button! If you plug the charger in and it does not instantly turn on - something is wrong. Start by unplugging everything besides the dc in board and the fan, now plug the charger in. What happens?
What's on PPBUS_G3H? PP3V42_G3H? PP5V_S4? What led up to it not turning on?
さんによる
If someome knows what is PPBUS_G3H, they won't be asking the question.
さんによる
Ok, you fix their motherboard then. Have fun.
さんによる
コメントを追加
See this Answer. Be aware that force starting a machine can cause damage.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 9,388
