メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
YLOD Repair not working?
I got a YLOD on my 20GB PS3 for the second time a few weeks ago.
After applying the fix, and reassembling my PS3, it worked for about an hour, then shutdown with a blinking red light.
It seems as though the system doesn't stay on if it heats up too much.
There is still some left over thermal paste, did I not apply enough?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
jlmcbmoo, here is my answer from a similar question. "First you do need to remember that this will only work if your YLOD is caused by solder fractures and if they are not to extreme.The YLOD is generated by cracked solder connections on the CPU/GPU. Reflowing any board with a heatgun, and even less with a hair dryer, is not an exact science and as such does have a certain amount of failure. One more important thing to remember is that a hairdryer will not generate enough heat (check on here Hair dryer for logic board reflow? for an explanation) to melt any solder. The proper fix for this would most likely be a professional reball. Anyhow, the biggest reason for failure to reflow is not enough consistent heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. You also need to make sure that you apply the thermal paste properly etc. If at first you don't succeed....:)." This guide will show you how to apply thermal paste. Hope this helps, good luck
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
zle896 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 212
