メインコンテンツにスキップ
モデルA1369、1.6、1.7または1.8 GHzプロセッサー、64、128、または256GBフラッシュドライブ
328回答 すべてを表示
締切られた回答
How do I repair screen blacklight?
Hi,
I have a MacBook Air that works, the display work I am able to see the screen at a certain angle and with light, but the brightness doesn't work. It is completely dark., and I try to all the trouble shooting with rebooting and booting in safe mode and the problem is still here, so I'm wondering how would I fix this problem? Do I need to change the fuse, if so how would I do it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Edward, you will have to check the fuse for continuity. Use a multimeter and see if it has blown. You also want to check the LVDS cable and the connector. Check closely for any damage. It is also possible that your wled driver has failed. To properly identify the location of the parts as well as the parts itself, post the last three digits of your serial number as well as a few good images of your logic board. This guide iFixitでの質問に画像を追加する方法 will show you how to add images to your question. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There’s no fuse or such a thing for this issue. It’s your back light. It’s gone. You need to change the light or whole lcd panel. Done.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 5
今までの合計 597
