メインコンテンツにスキップ
The Microsoft Surface RT (model 1516) is the first tablet released by Microsoft. It runs Windows RT, which is designed specifically for tablet functionality. Repairs for this device require screwdrivers and prying tools.
57回答 すべてを表示
Dropped my Surface RT and now screen has some sort of greenish static?
My Surface RT was dropped by my little boy, screen didnt break, but once any white page is displayed on screen, the tablet shows like some green static after i start touching screen. With that said, do you think i need a new lcd assembly? Or might it be a loose ribbon cable on the daughterboard or anywhere internally? Screen works fine with dark colors and shows that static with bright colors.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
選択されたソリューション
I suspect the driver chips mounted on the LCD panel has become dislodged. Unless you have some visible damage to the case which could have cut the ribbon cable. I would suspect the display needing replacement. Then it gets into the question on how much will it cost to repair. Did you talk to Microsoft yet? I would.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I do not have visible damage! So im guesing its just a chip dislodgement? Would that mean i can go into the surface and lodge it back in? because the screen works fine its just sometimes that it shows thegreen static
さんによる
I have not talked to micosoft yet but sure will the lcd display for the surface runs about 179 on amazon but i think ill have a chat with microsoft support first see if they can give me a hint to fix it! Thank you for your anser dan
さんによる
コメントを追加
回答を追加する
pelon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,815
