メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
締切られた回答
No connection to WLAN
Hi Guys, i have a big problem. since a few days my macbook cannot connect to wlan at all. no chance with a cabel aswell.
my macbook finds the right router and shows me that is has connected but i cannot open any website at all. and i hvae to give it the password after every restart. i tried everything but nothing helps. everything else works.(programms ect.)
the reason for that problem could be that i wlaked trough the city by very cold temperatures having my macbook just in my backpack. after i opened it after doing that i had to reset the time and the date.
pretty wired! do you guys have any ideas what i could do now??
thanks for your help!!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What operating system are you running? Did this start after a system update?
さんによる
コメントを追加
1 件の回答
ベストアンサー
I would start off resetting the SMC. Follow this Apple TN" Intel-based Macs: Resetting the System Management Controller (SMC. After you do you will need to check your network settings are correct.
Next you will need to get your WiFi AP's settings from a second system that is working or what you wrote down. Or if you don't have that info use a wired connection to your internet router so you can connect your system to the internet. Are you able to connect now?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 134
