Can we change the rear plastic iPhone 5c?
Hello. I'm French, so sorry for my English. I wanted to know if it is possible to change the back cover of the rather colorful plastic iPhone 5c. Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi, Elouen. It is possible to replace the rear case of the iPhone 5c. Just follow this guide to replace the case. You can order the rear case from the iFixit store.
このアンサーは役に立ちましたか?
Can anyone confirm whether or not you need to actually removed the whole front screen and parts on the inside to change the back... I've watched some videos that basically do that, but just want to make sure
will it afftect the use of the phone?
If you do decide to change it would it deleate or rest the phone memory ?
Hello. You can replace a new iPhone 5c back cover that is not a hard task.
You can find the colorful back cover for iphone 5cat witrigs.com.
このアンサーは役に立ちましたか?
once you take apart the iphone to replace the back is there any new part besides the new back housing? any new adhesive you will need?
Here's a site I found that sells the rear casings in every color:
http://www.etradesupply.com/apple/iphone...
However my problem is that I wish there were some sort of documentation on this. Well, time to watch the teardown 3 times through...
このアンサーは役に立ちましたか?
Yes the screen needs removed and the whole inside of the phone needs striped out and rebuilt in the new frame
このアンサーは役に立ちましたか?
are there any videos to watch to help you step by step to change the back casing on the 5c?
Can i go to the mall for changing my iphone 5c backcolor
このアンサーは役に立ちましたか?
this is a site to help you fix your own device. if you want to ask the mall guy then you need to go to the mall and ask him? try googling which phone repair people are near you or what services they provide...otherwise check out the guide on how to do it yourself (the accepted answer) and purchase the part to do the change
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 127,036
Couldn't you get in some legal troubles for buying a back housing containing the apple logo? Last I read (on some random forum), someone's $xxxx shipment of iPhone parts was withheld in customs for this very reason (Trademark infringement).
Be careful!
1di0t さんによる
