mower deck will not lower
I have a craftsman zero turn 26hp 50 deck but my mower deck will not lower or raise when i push the switch
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Same thing here! Called Sears, and they sent a repair man. $99.00 for showing up. The bottom side of the PTO knob (?) electrically connects to a clutch, the wires were ripped in half!
There is a metal finger about 2" by 1/4" welded to the frame that keeps the clutch from engaging when not needed. It had broken off, allowing the clutch to free wheel, cutting the wires.
The fix: disconnect the engine, remove the clutch and reweld the finger. Or, buy a new frame ($$?), buy a new clutch, about $250, finish by putting it all together again, more $$ for labor.
I declined the estimate because I feel, by looking at the broken finger that this is a case of either poor work, or inferior material since there was no outside force, concrete, wood, etc. that could have caused this. I ran over nothing but grass. I feel Sears is totally responsible and should repair it at no cost.
We'll see how far I get.
このアンサーは役に立ちましたか?
Wow, thanks for the info! It sounds like this may be a common issue.
Same prpblem
Drive screw got wet and will need to be sprayed with WD-40 or Penetrating oil
このアンサーは役に立ちましたか?
I just replaced the battery when my mower wouldn't start. It still won't crank and the electric mower deck that normally raises and lowers even when the mower is turned off, will not operate. The hour meter is still running though. Any thoughts?
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 14
今までの合計 21,073
