メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Replaced dock connector now no reaction / screen
Hi, I replaced a dock connector for an iphone 4 verizon. I followed all the instructions to a t - went to test it before putting the back on - and I have no reaction to it being plugge in.
the battery was out of it for about a month since I was originally sent the att version (did not realize until I was just about done installing.
Any suggestions on what I did or can do to fix it?
thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
If your battery was out for over a month, it most likely discharged. This means that if the dock connector that you received (the new one) was defective, which is completely possible even if it is new, you wouldn't be able to start the iPhone up from the battery or the charger. See if you can get your hands on a friend's charged iPhone and swap the batteries to see if it will start with a charged battery (then give their battery back). I have gotten defective chargers before, and if it turns out that it is defective, just try and exchange it or return it and order a new one.
Hope this Helps
- Owen
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
OK, so since the battery discharged it wouldn't work being plugged in. so I would need a battery either way. Confirming I understand.
but there would be no other issues that could cause the screen not turning on, recognizing a plug etc..
thank you!
さんによる
You don't necessarily need a new battery, it's just if it is at 0% and your new dock can't charge it, it remains at 0% till the dock works and can charge it.
さんによる
so just plug the iPhone in for how long do you think? I don't even see the battery showing it needs to be plugged in..
さんによる
コメントを追加
回答を追加する
swimmer35 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 90
