メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
All the time the wifi connect and not connect in my home
I have issues with my iPhone all the day the wifi is connect or not I try every think freezer , restart , reset as new iPhone , reset internet connection . Can some body can help ? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
最も参考になった回答
Hi,
If you tried "Reset Network Settings" and sw update next step is to re-hot or replace WiFi i.c.
Update
Sorry, I forgot - check WiFi antenna connector.
Regards.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for all the responses First I changed the router and this did not help and worked Rstart and this did not help. My question is where is the Ic Wi-Fi and what is his number ??
さんによる
Hi,
http://www.google.com.cy/imgres?sa=X&esp...
The problem is a cold solder joint or bad solder after a hit.
But WiFi i.c. is very hard for replacing. It's glued and you can make this only with hot air station and you must have experience.
Regards.
さんによる
コメントを追加
Have you tried restarting your router.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If this issue is only with wifi at your home but wifi works ok everywhere else, then like previous person suggested, you need to troubleshoot your home wireless modem.
EDIT/Update:
Is this your own phone that used to work, but then suddenly quit working? Or did you buy this phone used and it has never connected to wifi? Are you comfortable disassembling this phone? Do you have something like a jewlers loupe, or other STRONG magnification, so you can see the infinitesimally small circutry components? Was there water damage?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
yunissm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 166
