All the time the wifi connect and not connect in my home
I have issues with my iPhone all the day the wifi is connect or not I try every think freezer , restart , reset as new iPhone , reset internet connection . Can some body can help ? Thanks
Hi,
If you tried "Reset Network Settings" and sw update next step is to re-hot or replace WiFi i.c.
Sorry, I forgot - check WiFi antenna connector.
Regards.
このアンサーは役に立ちましたか?
Thanks for all the responses First I changed the router and this did not help and worked Rstart and this did not help. My question is where is the Ic Wi-Fi and what is his number ??
Hi,
http://www.google.com.cy/imgres?sa=X&esp...
The problem is a cold solder joint or bad solder after a hit.
But WiFi i.c. is very hard for replacing. It's glued and you can make this only with hot air station and you must have experience.
Regards.
If this issue is only with wifi at your home but wifi works ok everywhere else, then like previous person suggested, you need to troubleshoot your home wireless modem.
EDIT/Update:
Is this your own phone that used to work, but then suddenly quit working? Or did you buy this phone used and it has never connected to wifi? Are you comfortable disassembling this phone? Do you have something like a jewlers loupe, or other STRONG magnification, so you can see the infinitesimally small circutry components? Was there water damage?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 166
