メインコンテンツにスキップ
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
20回答 すべてを表示
How can I find an Eee 1005HA compatible screen?
I ordered a replacement monitor from a reputable vendor for our cracked Asus Eee 1005HA, but when I received the order, the two screen connections, where the wiring plugs in, didn't match (pic here).
I contacted Asus, which provided me the following information on the screen:
LCD TFT 10.1' WSVGA GLARE (A+)
Part number:
18G241010402Q
But I can't find replacements for that part number mentioned anywhere on the Internet!
Can I jerry-rig a connector for the monitor I already bought? They appear to have the same number of pins. The new, incompatible screen seller offer to exchange or refund it, which I'm happy to do if it doesn't work, but I really want to get this fixed.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
It was nice of Asus to give you part information!
さんによる
コメントを追加
3件の回答
ベストアンサー
finding an lcd should not be the problem - ebay helps
but since you've already got the wrong one, try to search for the lcd with the info's you got on the original screen's backside.
the asus part number won't help much - try to google it ;-)
search for us sellers and simply ask them about the connector
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
You need an HANNSTAR HSD100IFW1 panel.
I had the exact same problem - ordered a replacement LCD, and got the same type you got. Wasn't too happy about it because the eBay vendor stated it was for the 1005HA.
Luckily enough, I ran across this page where they explain the exact panel needed for the 1005HA.
Hope this helps. The Hannstar panels are found on eBay, but my problem is that the vendors show the panel back without the foil cover, and I'm not sure if I need to move the foil over or what. I'll find out soon enough. :)
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks! Would you mind updating when you get a chance to confirm it works? The netbook is still sitting, screenless and sad.
Thanks for updating here!
さんによる
コメントを追加
hi! it is 10inch screen, WSVGA (1024x600), Matte, you can buy from http://www.laptopwide.com/asus-eee-pc-10...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
HANNSTAR HSD100IFW1
available from Amazon
さんによる
コメントを追加
回答を追加する
Michael Morisy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 10
今までの合計 5,736
