メインコンテンツにスキップ
Apple社製パーソナルコンピュータ「Macintosh」の修理ガイド、分解情報。
42814回答 すべてを表示
Defragging Mac OS X hard drive
So I need to defragment the hard drive of my mac book so that boot camp will let me repartition it. I would like to avoid having to clone the drive and then clone it back. What are some good utilities for defragmenting (or any other tools that will help with the repartitioning problem).
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Dear Friends As Far As I Know Mac Itself Defrag It Drives You Can Clean Your Mac Computer Using Simple Steps Follow https://goo.gl/YT3sMw . See If This Helps
さんによる
I used iDefrag, and it worked fine. It not only cleared space for Boot Camp, but significantly improved the performance of my old (2009) MacBook Pro.
さんによる
First, before diving into list of programs, note, you should never use these programs on a Mac with an SSD. Otherwise, you can damage your disk and the system.
Apps for disk defrag:
- iDefrag is the most popular app. It costs $32 but provides a trial period.
- Drive Genius is a more powerful program, which allows you to perform a full range of preventive actions, work with HD partitions and restore the data. The price is $99.
- TechTool Pro 5 is a universal tool for Mac performance optimization, which has a defragmentation option as well. TechTool Pro 5 costs $ 98.
Resource - https://nektony.com/blog/how-to-defragme...
さんによる
コメントを追加
11件の回答
ベストアンサー
All the defrag programs look good, but I wasn't wanting to pay anything for this, and I didn't have a external drive I could back up to. So what I did instead was to zip up all the data files I had on the laptop (ie everything other than programs) then I copied them to a desktop. This took me from about 35GB free to over 90GB free space on the drive.
The boot camp utility was then able to properly format the 15GB partition I wanted. And then I copied everything back. I'm not entirely sure how boot camp partitions drives, whether it is in contiguous blocks or not, so this may work all the time, or perhaps not.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
matthewfrey is correct - you cannot repartition free space if it is not a contiguous block. iDefrag is a good choice, Drive Genius is another option. Using Carbon Copy Cloner or SuperDuper to clone the drive out and back is actually the best choice - faster, more efficient, and free. (plus you have a bootable backup, just in case)
asle is also correct in that OS X does not require forced defragmentation of the primary drive under normal operation (unlike Windows). OS X maintains proper fragmentation levels on the boot volume all on its own. In fact, you can make your system run SLOWER by defragging the boot volume!
Repartitioning a drive for Boot Camp is NOT a normal operation, however.
Defragmentation is widely recommended for external volumes used for video data storage - you want large continuous block of free space in order to prevent dropped frames.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
The question is, does OS X need a defragmenter. Mac OS9 did. I would say it can help if you have many large files (video etc.) or you are running low on disk space. For a starter Cocktail does a good work at maintenance (http://www.maintain.se/cocktail/index.ph...) although ti does not do defrag. You would need something like iDefrag (http://www.coriolis-systems.com/iDefrag....). I have tried iDefrag with good experience. But did I notice anything else than prettier defragement graphic bars? Not really, or someone else may have different experience. Take a read here about defragement and OS X: http://reviews.cnet.com/8301-13727_7-103...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I have found that Onyx is an excellent app for keeping my Macs in top shape. It's also free, which helps. There are many little tweaks in there that will get your system running as well as it can. Hope it helps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I ran into the same situation before myself - Bootcamp needs enough contiguous free space in order to partition the drive - I used idefrag, it worked well
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I am using Fusion to run Windows as a virtual machine. This may be one option for you - instead of buying a defrag program, buy VMware fusion. you can download a trial version (30 days) that can get you up and running at no cost immediately. If you don't like it you can still go back to your original idea
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If you want to defrag the drive and the cloning is not the thing that you want, then in that case you need to use any of the drive defrag software as it might be the case that defrag not let you defrag the files those are more than 20KB of size, while you are editing videos or images most of the file get a lot of space and these all files are out of Mac utility scope.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
TechToolPro can defrag I have the "for pay" version, I don't know if the free one you can download from apple does defrag?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Defragmenting in Mac Lion is almost not required at all. But when we are working with large files like media files, we need to defrag mac files using some third party defragmenting software like Stellar drive defrag.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can manualy do this process, but its risky nd unsure that's why it is better to take help from Tidy Up Mac tool. the tool has so many powerfult features that will help you to not only defrag your mac or macbook easily but also it Organize Macbook Files easily.
http://www.tidyupformac.net
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Although, defragmenting boot volume enhances the Mac speed. But it is recommended to backup important data before initiating this process. And CCC and Stellar Drive Clone software are good option for Mac drive cloning. There are many tools which can be tried as free demo version available online on their respective websites .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sedric さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 13,918
