メインコンテンツにスキップ
Which Philips screws on left edge of keyboard area?
In step 28 of the ibook g4 Logic Board Replacement guide, the accompanying image shows which 3 screws need to be removed.
The problem is, those top & bottom left screws are different sizes than the bottom right one. What size screwdriver do I need for them?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Unless they have been replaced with something different, those screws should just be basic phillips screws...any smallish phillips-head screwdriver should do it. I don't know the technical size of the screws, and it really shouldn't matter so much. If they are problematic, I sometimes use a slightly larger phillips, which can give you a better grip.
If you've gotten to step 28, you should already have a screwdriver capable of dealing with those screws, so I get the idea from your question that there's something more to it than that...are they torx screws, or possibly are they stripped?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks. They're neither torx nor stripped; they are standard philips head, but I think they're size 00 as none of my screwdrivers (0,1,0-2) quite fit them. When you get down to the tiny sizes, it seems that exactitude of fit matters more and more.
さんによる
コメントを追加
Small Phillips-head screwdriver.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jimryan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,345
