メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
20回答 すべてを表示
Horizontal stripes on 2/3 of my screen
Hi! Recently some bands of stripes appeared on 2/3 parts of my macbook's screen, these are more visible when I'm watching some dark/black pictures. I don't know if this is a problem of the lcd, the graphic card or any other?. Can u help me please? How can I fix them?
I attach a picture of my screen.
Thank u!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
If the artifacts constantly appear in the same place (location/sector) of the display they would have to be problem pixels on the display,
Connect to an external monitor - if you notice the artifacts on that display in approximately the same location they probably are from the VGU/VGC - if they do not show up it eliminates the VGU as a source of the problem.
If the artifacts move around as you move the graphic's window they most likey are a problem in the software that is decoding the video stream. You could try a different software (application) to see if the artifacts go away.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Never saw the picture of your screen.
さんによる
コメントを追加
回答を追加する
swheel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
