Is there any repair for netgear wireless router?
router is not receving power from the cable. can the router be repaired? if yes how much does it cost????????
awaiting your reply...
この質問は役に立ちましたか?
この質問は役に立ちましたか?
To start with have you tried a second power transformer. If you look on the bottom of the unit you should find a diagram which will tell you the units power requirements. I would suspect it needs 12volts 1Amp and the plugs inner core is the positive contact. Please double check this and locate the needed unit. What happens when you plug in the other unit and you press the power button? Does any LED's light up at all?
このアンサーは役に立ちましたか?
Any luck getting a new power transformer?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 937
8 件のコメント
please anyone do suggest me to solve this problem
vamsi krishna さんによる
Can you give us the products name & model number of your unit.
Dan さんによる
NETGEAR Wireless-N150 Router WGR614
vamsi krishna さんによる
vamsi krishna, "not receving power from the cable" are you saying that the router does not turn on? Receives power from what cable?
oldturkey03 さんによる
Here's a good resource Netgear N150 Router documentation
Dan さんによる
3件以上のコメントを表示
