メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
Is there anyway to repair fried motherboard
I have an iPod touch 5th gen that got submerged in a lake and now it doesn't turn on, the screen stays black and it heats up too hot to touch when turned on or plugged in. I know obviously something is shorting out but is there anyway to figure out what exactly is??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Jared, treat it the same way as you would treat any other device that was submerged. With any immersion, the importance is to not turn it on, or trying to sync/charge it, as this may increase the likelihood of shortcircuiting any components. Remove the battery, and disassemble it right down to the logic board . Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. If your LCD continues to heat up, I'd start with replacing that as well. Should this fail, you most likely have problems with the backlight IC and coil as well as multiple other components. Water damage is the most complicated repair since any one component can fail. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jared さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 1,153
