メインコンテンツにスキップ
廃番となったYashicaフィルムカメラの修理ガイドならびに製品サポート。Yashicaの商品登録は現在、香港ベースのMF Jebsen グループによって保有されています。
Are replacement lightseals/gaskets for Yashica 35mm cameras available?
Yashica TL-Super 35mm SLR camera needs the light seals on the door replaced. Do these seals still exist or is there a suitable substitute?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Sorry to say the foam rubber breaks down over time into a gummy mess. You'll need a good solvent to cut thought the mess (Toluene). Once you get it cleaned out you can use dense black wool yarn to replace it.
Get some contact adhesive and a cleaned out empty fingernail polish bottle with brush. Fill the bottle with some adhesive and thin it a bit so it's not stringy when you pull the brush out of the bottle.
Using the brush from the bottle paint the inner groove where the foam was located and before the glue dries press the wool yarn into the slot making sure not to compress it to much. You might find having a small wood stick cut to fit into the slot will help in guiding it in. That should do it!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
A guy named Jon Goodman (jon_goodman@yahoo.com) sells pre-cut foam seals for a large number of old cameras. Email him for more information.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sponge rubber works fine. Can be purchased in sheets for next to nothing in craft shops (comes in many color since it is popular with small kids to build all sort of things for mothers day and the like), these shops even have dedicated glue for it . After cleaning of the older seals (as described by Dan above), cut the sponge rubber to size. Most of the time you won't even need glue since the new seal will hold itself in place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rick Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 10
今までの合計 1,061
