The up arrow key is hot.
The up arrow key continuously clicks. Is there a way to inhibit this key in the operating system? An easy way to clean the keyboard? I believe I spilled Ice cream on it years ago...
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Have you tried popping off the key caps and giving the area a good clean? To start with make sure your system is fully off. Then get some distilled water (not tap!) with a cotton swab (Q-Tip) wipe down the area once your sure all of the water soluble stuff is off go over the areas again this time with a high grade isopropyl alcohol (85% or better).
Heres a good vid on popping the key caps off. YouTube Vid
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 91
