メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
Rebooting after battery replacement
I changed my iPhone 4S battery, everything went fine but after like 2-5 minutes the phone shuts itself off. I took the new battery out and the old one back in and the problem is still there... It is really frustrating...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Hello, I have the same problem. Have you find a solution to it ???
Thank you very much.
Marius
さんによる
is it an OEM battery? when you unplug the charger cable, does it turn off immediately?
さんによる
Can anyone help? I have the same issue with an iPhone 5. Tried replacing the battery and got the rebooting issue. Removed the battery and put the original and the same problem persists. Help!
さんによる
コメントを追加
2件の回答
最も参考になった回答
Sounds to me like the new battery isn't calibrated to the device. What I mean is that the battery may think it is 100% full, but because the phone hasn't gathered data such as the fully charged and fully drained point it doesn't know where it is. It could read 100% but may actually be fully discharged.
Turn it off and charge it overnight. Unplug it and plug it back in every once in a while during the process to make sure that the charger pumps a little bit more juice in each time. See if you can do a factory reset too, only after you try to charge it overnight though.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm having that same rebooting problem too after simply trying to replace a 2 year old battery. Every few minutes it reboots and it's worse when it's plugged in and charging. Has anyone figured out a fix for this that doesn't require updating my version of IOS?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Max van Soest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,171
