Installation BD-ROM instead of DVD optical drive
Is it possible through any adapter to connect SATA BD-ROM to macbook pro early 2008 ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
No you can't install a SATA optical player where a ATAPI (PATA) player was. The connections are not comparable and there is no adapter (connector & signal) small enough to fit between.
このアンサーは役に立ちましたか?
Toast for Mac offers Blue-Ray support.
If thehardware has a driver (extension) for it then you can find software to make it work. Back in the day we ran a Hack so that PowerBooks could be upgraded from CD players to burners and DVD player/burners. I don't remember the name (it's probably been 10 years since I used it… could have been called Burn… anyway I digress.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
I would like an internal blue ray optical drive for a laptop, as the link with EBAY. But there connector SATA , in my Macbook Pro connector atapi. Is it possible to combine them physically?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 373
2 件のコメント
First have you addressed the software issue, Apple doesn't provide any software to watch or write Blu-Ray on your computer. So you need to use third party softwares to watch, backup, edit and burn Blu-Ray discs.
mayer さんによる
Ok, I think this software is because they are being sold for models unibody. The question in the plant.
Vitali さんによる
