メインコンテンツにスキップ
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127回答 すべてを表示
Display - Screen colors go fussy
The display screen on my Samsung Galaxy Note 10.0 note goes fussy and the screen does not always respond to touch. I don't know if it is the screen only or the digitizer. The tulips are my screensaver and what happens is that the edges of the tulips start becoming fussy and the colors start changing. Please let me know whether I should buy a new digitizer and if so please let me know how to install it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
That sounds like the LCD. The digitizer wouldn't change any coloration. Also take in to consideration if you left this device in the direct sun for a long time or in a vehicle it may be a GPU overheating issue. If not. I'd say LCD. Just my opinion. Good luck.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I had this same problem of fussy colors. I left it in my car facing the dun for long. How do I get my right colors back?
さんによる
I need advice for my samsung note 10.1. Mostly fuzzy screen and blue shadding around pictures. My blue screen for the signing in to samsung is now green.
さんによる
I am having similar problem as the last comment with my Note 10.1. The screen is mostly fuzzy with a royal blue color around pictures/objects on the screen. Can this be repaired? Grandma Sil
さんによる
コメントを追加
I faced the same problem before. I sent it for repair and the technician said it was due to a flex cable problem.
After replacement, it can be used as normal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Julie Dobbs さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 2,322
