メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
Isopropyl alcohol in LCD - will it go away?
Hello,
I wanted to clean my iPhone with isopropyl alcohol today but obviously used too much of it.
It has gone inside and I think it's somewhere between the backlight and the LCD.
It's 99,99% alcohol.
When the phone is turned on it shows stains as you would see if you put water on two panes of glass and press them together.
Also some parts are brighter, some darker.
My question is if I need to replace the LCD assembly or if this "damage" will go away if I wait some time.
I would be grateful if you could answer my question.
Thanks very much!
- Daniel
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
5 件のコメント
Hey I was a dummy and accidentally did the same thing to my 4s today as well because I was in a quick hurry and didnt bother removing the logic board this time around... Most of the visible stained area went away, but a good deal still remains... Any tips on cleaning this out properly?
さんによる
It's really, really difficult. I haven't even had a lot of luck soldering on a new backlight -- dust is very, very good at finding its way back there. Easiest way would be to replace the display assembly.
さんによる
Fortunately, most of the alcohol evaporated and the dark stuff in particular is completely gone now... only have a few very bright dots now spattered along the top of the screen... curious if those will eventually go away as well after just being exposed to more heat potentially.
さんによる
Shaun Brown, could be but most likely those are the impurities washed up from the alcohol. So they may be of the more permanent type ;-)
さんによる
How can i remove 70% alcohol trapped inside my display.. Will it cause permanent damage?
さんによる
コメントを追加
1 件の回答
ベストアンサー
shagrinar, the isopropyl should evaporate quickly and will not harm your display. Worst case scenario is that you may get stains in there, from impurities that got washed out by the alcohol.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I agree with OT the dirt & oils it picked up left the stain.
さんによる
How long would it take
さんによる
I was cleaning my screen with an alcohol
Then suddenly my phone is damage with an alcohol but it's still works why?
さんによる
コメントを追加
回答を追加する
shagrinar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 63
今までの合計 15,359
