Dual Hard Drive install procedure
Hi,
I have read your install procedure and some cable seems to be a little risky to remove. I also discovered the OWC procedure which seems to be less invasive as they propose to remove some screw and just move a little the airport/bluetooth module instead of completely unplugging it.
What do you think? Will it also work with you Dual HardDrive Case?
The OWC procedure can be found here http://eshop.macsales.com/installvideos/...
この質問は役に立ちましたか?
