メインコンテンツにスキップ
Sleep / Wake Button Not Responding
I accidentally tore the flex cable when replacing the screen.
The old cable was removed and a replacement installed.
The sleep / wake button does not respond. However, when I press Volume Up or Volume Down it takes a picture. So is it the power / sound / mute flex cable or the logic board or the power flex cable connecting the logic board to the motherboard?
Or?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Thomas,
I would guess that it's a bad cable. I would try a replacement from a different supplier. Or send the one you have back and see if you'll get a replacement.
I doubt it's the logic board. I would unplug the cable and then plug it back in and test. Look at the contacts on the connector, see if there are any signs of damage.
That's my best advice. You'll have to do some troubleshooting from here.
I hope that helps you some!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
Its definitely a bad adjustment of flex cable. Try not to go for a cheap flex as cheap flex usually have this kind of problem. I would suggest you to let a technician change a flex this time for you.
Good Luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thomas Garbarz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 658
