Typed real_mode in Open Firmware, Pismo won't start up.
I like to get help on this one.
I can not find the answer anywhere on the net so here it is.
A while ago I connected My Pismo to a PC in Target Disk Mode and after that the firewire port didn't work so I got into open Firmware and did the usual Reset nvram, set defaults, reset all commands,nothing after that but after I think using only reset nvram it worked but then My laptop got very slow (painfully) although processor time was idle (Odd),restarting and resetting with all 3 commands solved the slow response but then My firewire port didn't work again, also not showing up in System Profiler.
So I fiddled more in O.F. and typed in (I am almost sure it was the next command) setenv real-mode yes.
After this the pismo starts up but gives Me a black screen, no activity at all from the internal disk, yes it spins up but that's it,no read write I can hear.
It's not a hardware failure!
I tried resetting the Pismo with the reset button, got the battery out for a long time, also power off but to no avail.
I can Not get into anything, not even O.F.
If I hold the start button I get a few beeps and after keeping the button down it restarts and after a few seconds the display will light up but 2 seconds later it shuts of again.
Is there anybody knows what this (real-mode) command does and how to reset it?
Starting up from another internal disk with a clean OSX doesn't
work either.
Help please, cheers Perry
この質問は役に立ちましたか?
