メインコンテンツにスキップ
Model A1046 or A1095 / 1280x854 screen resolution
118回答 すべてを表示
PowerBook DVD+R DL Loads Too Slow
I recently put 10.5 On a DVD+R DL and inserted it into my Powerbook Model A1046. It loaded after quit a long time then I clicked install and restarted the mac it loaded up to the apple logo and stayed there for a long time with the drive making a funny noise like speed up and slow down rapidly but scratchy
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi
Maybe the DVD is too scratchy for the drive or the drive itself is dirty; I got two MB in the past with non-working superdrive. After vacuum cleaning them and cleaning the lens with a q-tip (carefully) they work like a charme.
Regards, Stone
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
That may be it but it playes CD-R with no problem Could the Image file be currupt?
さんによる
Ah, now I see :-)
I had the "problem" that even with a original retail DVD of Apple the drive was moving a lot its head / lens, in opposite to many other DVDs and CDs.
Of course, if the DVD was made by a image file, the image file might be corrupt; I think this could easily checked by inserting another DVD, e.g. a movie DVD (at least it should state that it can't play the DVD because of encryption).
Regards, Stone
さんによる
Thanks for your answers I have solved the problem with your help turns out my drive doesn't support dvd dl disks, it will play them but it takes it too long. I have gotten my drive to do what I wanted and solved this problem
さんによる
コメントを追加
回答を追加する
Valiera さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 112
