Do you Know exactly model of chip video
Do you Know exactly the model of the chip ATI X1600 for powerbook A1150....
is this ATI X1600 216PLAKB24FG BGA IC?
what is the difference between 216PLAKB24FG and 216PLAKB26FG
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
There are two revs of the chip one at 398 MHz (which is what Apple uses) and 450 MHz. Apple uses the lower clocked chip because of heat issues. Heres a good reference techpowerup
このアンサーは役に立ちましたか?
Thanks! this one works?
Cynthia - While its the correct type of chip it may not be the correct clocked version. This is the one you want: http://www.techpowerup.com/gpudb/2336/mo... Vs http://www.techpowerup.com/gpudb/1603/mo... Sorry to say they used the same graphic for both chips so you can't see the differences in the markings.
Do you know where i can buy it?
Thanks for your answer!
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 250
3 件のコメント
what are the last three digits of your serial number? This will allow us to properly identify your computer and your logic board.
oldturkey03 さんによる
It is the M56P [Radeon Mobility X1600]
oldturkey03 さんによる
The serial is W86086XDJ0
Cynthia さんによる
