Cannot install Tiger 10.4 software.
I have install disks for my iBook G4 however when I attempt to load disk 1, I get a Panic CPU 0. Cannot find driver for Powerbook 6.5 platform. Also says that debugging is not configured and debugging info is being discarded, then hangs. Will not boot in safe mode.
この質問は役に立ちましたか?
5 件のコメント
Are you certain you're using the proper OEM grey disks?
originalmachead さんによる
It is the retail version of Tiger 10.4. Was told it should work on my iBook G4, 1.33 Model A1054. Yes, they are the grey disks.
Dan Kern さんによる
Can you give us the last three digits of your S/N.
Dan さんによる
ROQ are the last 3 digits of the iBook G4 serial number.
Dan Kern さんによる
Do you want to double check your numbers. I can't seem to find your system in the database. Here's the tool I use to verify what your system is see if you can get it to find your system EveryMac.
Dan さんによる
