メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Can dual hard drive kit be used with a data doubler kit?
Trying to keep the original hdd drive in my mid 2011 imac, and maybe misunderstanding that I can add 2 ssd drives via cables and a data doubler!! Am I off base on this idea?? Through your ifixit company 1 ssd drive will go under the optical drive, but using a data doubler will use the optical drives existing space. Is this far fetched or this is correct?? Thanks for any help on this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
You only have three SATA ports in your system (older models only have two). There is no way to split the SATA port (expanding beyond what you have).
Currently you have two in use (HD & Optical drive). Apple added a third port as people wanted to use a SSD for a boot drive (to speed up the boot up). Later on Apple introduced the Fusion Drive service to make managing the storage space easier as one unitized volume and allowing the OS to place the files on the best storage area.
If you want to hold on to your HD & Optical drive then you have the third port to connect your SSD to using the special Apple SSD bracket ($$) or just some double stick foam tape (the SSD is not very heavy). If you add in a second HD I do recommend the bracket as the heat dries out the tape.
If you want to add in a second SSD (or have an older iMac) then you can use the OWC (Data Doubler) or iFixIt Optical drive bay carrier replacing your optical drive.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It is correct but it's a lot of work. Getting and using one large external drive is much simpler.
If this Answer is helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Timothy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 838
