メインコンテンツにスキップ
2009年6月発売/ 2.53 GHz Core 2 デュオプロセッサ
170回答 すべてを表示
Swapping Entire Internals from Matte to Glossy MacBook Chassis
Hello everyone,
Thank you for taking the time to read this.
I own two Macbook Pro 2009 Model A1286's.
Computer A is a Matte Screen version
Computer B is a Glossy Screen Version
Computer A has display issues (2inch vertical band of multicoloured lines just to the right of the sight camera) as well as a battery that doesn't hold charge very well.
Computer B suffered liquid damage on the logic board and does not power up.
Computer A (matte screen) is very well used and the housing is scratched/dented/dirty etc.
Computer B (gloss screen) is in almost pristine condition, it is only the internals that are damaged.
What I would like to do is swap the entire internals of computer A into the chassis of computer B.
Should I face any issues doing this? Is it as simple as simply swapping the logic board and hard drive from computer A into computer B?
I appreciate anyone taking the time to answer this.
Thank you.
Janaka
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
If you feel your up to doing it, two exact systems should be no problem in swapping things out.
Take your time and make sure you have a few egg crates to hold the screws and small pieces and the proper tools.
The only thing I can think of is the water damage system may have a few corroded screws.
Also, don't forget to use proper ESD protection as you'll have the logic boards exposed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Janaka Rodrigue さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 167
