メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
What to do next? Battery replacement problem.
Ive stupidly tried to remove the battery connection with a flat head screw driver whilst the phone was on. I saw a small spark come from the phone, reassembled it perfectly now it wont turn on. Any idea which component i would have broken?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Why use a flathead when the screws are + shaped
さんによる
コメントを追加
2件の回答
ベストアンサー
you may test your components independently. The only thing you may hope is not to have endamaged battery connector pins or the logic board. Next time, you'd rather use a plastic knife for example and an anti-static wrist strap. You may find all you need by following the links below.
Hoping to have helped you,
Give us some feedback
Vincent !
[リンクされた製品が存在しない、もしくは無効: IF145-047]
Digital Multimeter
Digital Multimeterの画像
製品
Digital Multimeter
$19.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well by suddenly disconnecting the power, you could have done damage to the software of the iPhone. You should always turn it off to prevent damage and data loss. I would think you may have to replace the battery. Also check to see if anything looks different ie there is an area that has turned black . If thereis gently clean it using isoproyl alcohol not the kind that you have in a medicine cabinet, that has to go low a concentration. Get some with the highest concebtratiom you can get. Then clean the area where u see damage and if that does work the part may need to be replaced.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vinnie Ebbrell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 167
