メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
20回答 すべてを表示
iPhone 5 dead LCD after rear case replacement
I replaced a customer's iPhone 5 rear case today and now the LCD appears completely dead. The mute switch makes it vibrate so I know it's on but replacing the front didn't help (or a hard reset obv).
Could I have blown a fuse or what could be the problem?
The logic board doesn't appear damaged.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Mabe could you verify that the connectors are connected well and all the pins absolutely clean. It looks like your display is just not supplied/connected. Remind that even a small peace of dust can cut the connexion...
Hoping to have helped you,
Give us some feedback !
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Absolutely clean and connected :-/ I'll have a partner put it under a microscope today.
さんによる
コメントを追加
Hi
Happened to me the same problem, what I did was to inspect well near the connectors and set me well that a connector had broken and what I did was I made a bridge with a silver writer. and it worked but I had to connect a new screen for it to work and then place the iphone screen.
And iphone is working properly
Bad Part
http://www.flickr.com/photos/99104195@N0...
Fixed with Silver Writer
i use a Macro Lens for iphone 5
Link Silver Writer
http://www.amazon.com/CIRCUIT-WRITER-SIL...
never use it direct the writer, put some on a sheet with something that has the fine point you can do it without touching other connectors or you can make a short circuit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello Anders,
How did you fix it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anders さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 822
