メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
645回答 すべてを表示
How to replace the LCD lid Back Cover?
What steps need to be followed to replace the Unibody A1342 LCD lid Back Cover? There are a series of cracks on the lid cover near the hinges and in the middle of the cover. I have a new lid and I assume I will need to follow the LCD panel replacement guide. But there is the camera, etc. What else is in there?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Just follow the steps to replace the display assembly and the display cable , then re-assemble into the new lid instead of the old lid! :-)
MacBook Unibody Model A1342 Display Replacement
MacBook Unibody Model A1342 Display Data/Camera Cable Replacement
MacBook Unibody Model A1342 Displayの画像
ガイド
難易度:
難しい
15 - 45 minutes
MacBook Unibody Model A1342 Display Data/Camera Cableの画像
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Henry !
The best thing you could do here would be following one of these two Teardowns, which show you how to disassemblate your whole MacBook.
Hoping to have helped you !
Don't forget to give us some feedback :)
Vincent
MacBook Unibody Model A1342 Mid 2010 Teardown
MacBook Unibody Model A1342 Teardown
MacBook Unibody Model A1342の画像
ガイド
難易度:
中レベル
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks, Vincent. I had actually already viewed these two excellent tear-downs only to find that they do not tear into the LCD display lid; and so I posted the question about what else is contained in the old lid that will need to be moved to the replacement that I bought. The LCD replacement guide is pretty close to the mark, but it looks as if the antennae and the camera remain untouched.
The cracks in the lid hinge is a very commonly reported problem, so I feel certain that some daring soul in this community has replaced the back cover on a white unibody. I would be honored to benefit from that experience.
Thanks in advance for replying.
さんによる
I think I may have found the path to success! There is a Guide here called "Rear LCD Bezel removal." It looks to me as if that series has all the parts I could anticipate needing to move to the new LCD back cover. I will report back after I receive the replacement part to be sure that the frame is indeed included in the back cover.
さんによる
コメントを追加
回答を追加する
Henry Gardiner さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 2,857
